In game calibration - Tacx flow smart T2240
(Michael Ahlers) #1
Hi all,
Although it is supposed to be working, the trainer calibration button within Zwift is not available. I upgraded to the latest firmware of the trainer and used it in zwift several times now, I never see the calibration button.
I use a Windows 10 PC with and ant+ USB adapter. The Tacx flow ist connected as the controllable trainer and power source. For cadence, I use the wahoo cadence sensor as it is more precise.
What am I doing wrong?
Thanks!
Michael
(Paul Graham) #2
Hi Michael
Have you selected the FE-C component of your trainer on the pairing screen?
(Willis Weigand) #3
Michael,
I had to calibrate my TACX Flow with the TACX utility downloaded from the TACX site.
(Anthony Todd) #4
I have the same trainer, and the FE-C option does not seem to be there when you pair the trainer.  It does state Ant + , but not FE-C.    It does calibrate with the TACX utility and Zwift controls the resistance fine.  Any ideas on why the calibrate / FE-C option is not available on Zwift ?
(David Griffin) #5
I would be grateful to know how to get this feature working, I find it a right pain in the bum having to calibrate on phone prior to going into zwift.
(Alan Rossiter) #6
I’m in the same position…the Trainer is not listed as being able to connect via FE-C. I have updated the Tacx Flow firmware and used it twice but the FE-C option is still not available. Any thoughts on whether this is a Zwift problem, an ANT+ dangle problem or the Mac being a problem.
