If you use a CycleOps Jet Fluid Pro with the clutch knob design to set resistance, can you advise how many turns it takes for the clutch knob to click AFTER the resistance unit initially touches the tyre.
Also what tyre do you use & at what pressure.
Thank you in advance.
I have a CycleOps Fluid2 with the same mechanism. I think it’s abbout 3-4 full turns of the knob before it clicks. I found that quite tight so i turn it until it contacts my tyre (TACX Turbo specific Tyre) then count 2.5 turns more and leave it at that. I release it when not using turbo then re-tighten when working out.
