I cant update error Z113 Line594
(Hiraku Edayoshi) #1
i cant start zwift.
error Z113 LINE594 happen when first launch update.
Need help!
(GABRIEL MIHAILESCU) #2
I cant start zwift.
Need help!
(ronen zelikovitch) #3
I cant start zwift.
Need help!
(Pizza Eater) #4
I have the same shit but with z117 this is also my first install. I havent had luck with run as admin. Is there an alternate way to install this software? Perhaps a workaround entire folder uploaded to googledrive or something else … i just want to try zwift !
*EDIT*
I tried it over and over and then it finally worked, if you persist then it might update bit by bit before it crashes, then eventually itll be near the end of the full update and complete without any hiccups. Might take a while if you’re unlucky.
