HRM issues connecting
I’m having issue connecting my HRMs to Zwift I have x2 HRM neither will connect but work on other platforms ??
What are your HRMs, and what are you running the game on? Are you trying to pair them directly or via the Companion app?
Which trainer are you using? (Asking because I want to know if it supports sensor bridging.)
Good afternoon I’m running Garmin HRMs and i’m using Wattabike as my trainer.
The Wattbike does not support sensor bridging, so that option isn’t available.
If you haven’t tried pairing through the Companion app, that is something you may be able to test. Using the Zwift Companion App as a Bridge
What are the models of your Garmin HRMs and what are you running the game on?
