Do how dose the apple tv work can i connect it to a projector as im in the process of making a man cav in the garden out building that i wont to have my bike set up in with a pull down screen
Shouldnât be an issue since the ATV has an HDMI port.
Can you ANT+ on the apple tv or is it just Bluetooth
Itâs Bluetooth only. If you want to use ANT+ sensors you will have to use the NPE CABLE or 4iiii Viiiiva HRM to bridge the signal.
How do you get HR as i have garmin HR strap thats ANT+
I am guessing itâs not a Garmin Dual HRM. I would suggest getting a dual band HRM like the Wahoo Tickr, I have seen more than a few issues with the Garmin Dual connecting to Zwift.
Ok cool thanks for all the help the apple tv 4k looks like the best op just need to get an applphone as well to work it all or can you do it of an android phone
The Zwift Companion App can running on iPhone or Android and still be able to connect to Zwift running on ATV as long as they are both connected to the same router.
