I have the Gamrin HRM-Tri™ which is not compatible as it has only ANT+.
So I cannot decide if I should buy the HRM Pro or the HRM Dual which is a lot of cheaper than the pro but without Running dynamics.
Does it make sense to use the strap running dynamics on a treadmill in combination with Zwift?
Or will it be a better solution to use my standard equipemnt - Fenix 5x linked wioth the strap and use Zwift without monitoring the heartrate?
