When I’m on the sensor screen after starting up there’s no connection with my HR sensor. After riding a while (like 5 minutes or so). I can connect to my HR sensor.
It doesn’t connect automatically neither, I have to go back to the menu and then it connects.
It’s not a problem of the sensor since it works perfect on my garmin.
Apple’s tvOS limits the number of concurrent Bluetooth LE devices to 3 different devices (including the Apple TV remote). You don’t detail how many BLE devices you are running, but I wonder if that’s the issue at play for you?
You might be able to use the Zwift Companion app on your smartphone to act as a bridge to connect the heart rate monitor. See this Knowledge Base article for more information:
Garmin heart rate monitors connect via Ant+ and thus will not connect thru Bluetooth. There are dongles and other connectivity items that allows this but they are more costly than just buying a Bluetooth HR monitor. The Wahoo tickr is about 50$.
It had nothing to do with the Bluetooth or ant+. My HR sensor had BT and Ant+. And I only use 2 BT connections. The wahoo kickr core (has build in cadence since last update) and the HR sensor.
The weird thing is that when I start to ride it works after approximately 5 minutes. But not automatically, I have to go back to the sensor menu.
Which HRM? ANT+ and BLE work independently of each other, so being connected via ANT+ to your Garmin watch doesn’t mean BLE is already enabled. Maybe it just takes five minutes for BLE to wake up.
