My Strava uploads from Zwift aren’t showing Heart Rate data. I know the FIT file sent to Strava contains HR (use ‘download original’). Anyone else notice Strava isn’t displaying heart rate? Garmin displays it just fine. The rest of the Strava ‘presentation’ seems correct - has the map, image(s), elevation data, etc. Strava even knows the HR during segments, but doesn’t display the line graph for HR over the entire ride. I’m wondering if its related to the FIT file apparently containing two different HR fields per second, one that looks legit and a second 16-bit field that contains 0xFFFF ?
mien is showing fine in strava, what hr device do you use?
Garmin HRM-Pro Plus. HR shows up in-game, in Garmin Connect, and in the FIT file itself. Most curious, but I’m not fond of that second field in the FIT file ‘RECORD’ records.
Never mind. The HR graph is there; its just not in the Overview section where I see it on all my other activities. Its found under ‘Analysis’, I guess because its a ‘ride’ instead of a ‘run’ or ‘walk’ activity.
I don’t need HR in Strava, didn’t even notice its not there, just use the free Zwift companion App for HR and also get signed up to ZwiftPower. The Companion App has all your HR zones you need to stick to for training, don’t need anything else.
