Gym strength training and zwift coach
Does zwift coach take into account any off the bike strength training ?
Strength training off the bike is one of the biggest gains u can make while cycling. But none of the AI powered coaches seem to do it justice. How does zwift fair at this?
At present, the Zwift Coach functionality only seems to take Zwift rides, and probably rides uploaded from Garmin are Wahoo, into account (though there doesn’t seem to be a way to export the Zwift workouts to Garmin or Wahoo). That may change in the future, but is not a current feature.
This a very big oversite of the Coach. Very out if touch with standard training recommendations for some time. Guess this AI has not been trained properly. Many much better solutions available!
I’m critical of zwift, but talking into account strength training is pretty advanced. How would you see it doing that, realistically?
Don’t get me wrong, an LLM will do it pretty well, but does join/trainer road do it?
A software like join.cc uses RPE or TSS. But the only correct way is if the app either lets u log the excercises through them (like hevy, garmin or even strava) or receives that data.
It’s hard, but it is something one could really distinguish themselves from the others with. Anything is better than nothing though, but overall the it’s still something missing in the market afaik.
I see strava now integrates with claude. I bet this is a much better ecperience than offered by Zwift or the other more established adaptive training apps.
Dean, for more novice level athletes maybe not much. But as your training load increases, the more important it becomes. Easy example, a coach would most likely not plan strength training in the morning before work and then later a hard VO2Max or Anaerobic bike sessions that evening. I have been thinking about it, ideal starting point is for Zwift Coach to allow you to schedule activities as Others with an associated duration and load. Not perfect a good starting point. This would allow anyone doing multi-sport to add it in. I tired doing this with running though cannot add load. I would like to add swimming too. This would dramatically improve the ability of Zwift Coach to plan your load across the week and understand when to add recovery time. It already is collecting it if you have linked it in, now just use it in the plan. This first version is way to limited unless you are at more beginner level and only doing cycling. Even in running they not planning for the loads (even if you run on Zwift).
I think your message demonstrates how this falls into the advanced category when zwift is launching more of a minimum viable (saleable) product here.
And its pretty common to combin3 lifting with vo2s isn’t it? Under the generalised principle of keeping hard days hard and easy days easy. Goes to show it pretty advanced stuff..
I thought empirical cycling talked about this but actually, its the trainer road folk.
Dean, doesn’t it depend? If those starting the fitness journey probably notb the same day, but as their fitness improves that would be the natural progress. If you have substantial fitness, probably so. But then if the you would want a rest day with that training in it?
I agree this is that this might be just a basic new offering. Given the available solutions, this is sort of a basic one to add without much effort. It would really help those starting the fitness journey these days. I also would agree with Eric S that is really makes it easy to execute the plan, pretty decent UI.
Anyway I hope it becomes useful to the athletes using it :hugs:
