Hello,
when I join a group ride all the riders participants sometimes disappear from the screen and come back a few minutes later.
Usually at that moment I lose contact with the group because I ride alone.
Anyone else having this problem?
Good morning @Saub_65
Welcome to the forum
This is a sign that your device cant communicate with the servers, check your network connection.
Thanks Gerrie.
it is a fixed internet connection, no wifi.
meanwhile I watch live concerts on youtube and they continue to work.
Every now and then I get the message “connection disconnected” but everything continues to work.
You can put your log file in https://zwiftalizer.com/ and look at the network traffic.
Also YouTube is different, it will buffer a lot of information so even if you have a few seconds of no data you won’t notice it because that data is already stored.
ok thanks.
I will check it next time.
You can your your previous ride’s log file.
Ok.
then I can check it this evening.
Saub,
This used to happen to me a lot when I had my Apple TV hardwired to my router, it actually stopped when I switched to wifi.
I have no idea why, but I’m sure other more technical people might be able to advise.
Paul.
Thanks Paul,
I try wifi to check if its better.
Hi all, problem solied.
There was a bad connection between two cables.
Still working hardwired now.
