Trying to do my first ride. Im set up correctly but am not seeing any prompt to do a ride. The dashboard is blank. Ideas?
Hi Dawn,
It sounds like you are trying to run Zwift from the website. You will need to run it from the application you previously downloaded and installed onto your computer. There should be a shortcut on your desktop.
If on a Mac, it should be in your applications folder or you can use Spotlight by just hitting Command + Space and typing in ‘Zwift.’
