GEONAUTE ANT+ 2 HEART RATE MONITOR BELT
(Drew Doyle PTz) #1
I have purchased the following: GEONAUTE ANT+ 2 HEART RATE MONITOR BELT
But i am having no luck with the ANT+ pairing, i know the ANT+ Stick is working ok as my trainer connects fine through it, any help much appreciated
Thank you
Drew
(Peter Everitt) #2
If this is the dual Ant+ and Bluetooth unit then I have one and it works great. However it did screw up once with the Ant+ transmission and I had to remove the battery then put it back in. After that it was fine
Good Luck
Pete
(Drew Doyle PTz) #3
Hi Peter,
No this is just the ANT+ version, do you know is there anything i have to do to make it visible for pairing other than putting it on me?
(Jason K) #4
There’s nothing else you should have to do other than make sure it’s on and transmitting on our end. You may want to see if it’s transmitting in other software/on other devices to verify it’s working, and contact the manufacturer for more troubleshooting if it’s not.
