Gemini210 cadence problem
My use environment is as follows.
phone: galaxy s7,
power: misuro b +,
cadence gemini210
Symptoms cadence information is not accurate.
Alternating between normal and abnormal values.
This is not a cadence sensor issue.
Using gemini210’s manufacturer software, cadence information is found to be normal.
Or it works well in rouby.
misuro b + supports virtual cadence.
This is normal.
If so, can you check the protocol of the cadence information sent by gemini210?
Hey Gemini, can you send us a technical support conversation with your log files? Triple tap the Zwift logo at the start screen to access your log files from your most recent rides and send them.
