Gearing problem -
Hi! I use Elite Suito trainer, it is my second winter with it, last year I used it with my gravel bike, this year I want to use MTB. My problem is the gear range, I will give you some details first:
  • gravel setup: 39/26 crankset, 11-42 cassette (570%)
  • MTB setup: 32 crankset, 11-51 cassette (460%)
When I used gravel bike I used almost whole gear range and very rarely run out of high gears, now when I ride with MTB I use 3, maybe 4 hardest gears and on flats and descents I run out of gears while riding 30 kph. Is there a way to configure Zwift to “think” that I use 40T front ring instead of 32T?
Zwift has no solution for this problem with that trainer, but you can probably use the QZ app to get virtual gearing on a phone or tablet. You pair the trainer to QZ and you pair QZ to Zwift. It sits in between and does some magic to let you increase the resistance. qzfitness.com
@Roberto_Viola is the developer and he will assist you with any issues.
Hi! QZ developer here! Let me know if you need help setting the app!
Thank you!
Hi! What do I need to do to adjust gearing? I tried to adjust resistance but it does not change, it is zero all the time, I tried to enable and disable Auto Resistance, that does not change anything.
“Thank you”, I bought your app, could not get my goal and got no answer from you…
I didn’t receive the notification from the forum! So sorry! send me an email to roberto.viola83 at gmail.com
