Gear to Power Relationship Off - Zwift Hub & Click v2
I have a Zwift Hub and Zwift Click v2 controller/shifters and the setup has worked fine for almost a year. In the past 3 weeks I have had two instances where the power I need to put out in a certain gear is way off from the usual. I know that in the sequential 24 speed setting, putting out 150-160W on a flat in gear 15 allows me to cruise at 19mph or so (depending on the game surface). In one instance I needed to put out above 200W to do that. In today’s instance I could maintain 19mph in gear 13 at about 140W. Both times the glitch showed up were on un-rubberbanded group rides. The firmware in the Hub and Click are up to date according to Zwift Companion. I run Zwift through a laptop and the BT connections work flawlessly.. I put the applicable log through TrainerDX and the only thing the report highlighted was that the laptop CPU is obsolete and the game graphics are not at their highest quality (not a big enough deal to me to spend $$ to replace the laptop). I tried changing the gearing during the rides via the hardware settings from the 24 speed to the climbing setting and then back again, but that didn’t fix it. The odd thing was today I warmed up on a Watopia route and everything was fine, but once I joined the group ride (a NY route) my setup was off. Any ideas on what I might investigate or check further?
Thank you,
John
there are a lot of variables here, so keep that in mind. Were you with a larger group here so the draft effect was bigger? Different bike that was faster or had higher upgrades?
No, exact same bike, riding with one other person. Nothing different from what I normally encounter, that is why the change was so noticeable. Also, the first time it happened it was with a larger group, so having to push more watts was striking considering I was well insulated in a pack.
Can you calibrate the trainer? Do a spindown?
There is no spindown available for the Zwift Hub. It either auto-calibrates in the background, or… nothing.
What’s maddening is that the setup has worked perfect for almost a year. The glitch happened before the latest update so that can’t be the root cause.
The usual way that auto-calibration works is you get the trainer up to speed, stop pedaling, coast until the flywheel stops. I honestly do not know if this is a calibration problem so that may not help you, but you should understand how it works.
The other thing that can affect the amount of resistance in a given gear number is the shift style and gear range settings. So if settings got reset or something like that, it could affect what you feel. If you want to experiment with that, check out this document: Shift Style and Gear Range
