Just did an update to zwift on my ios macbook. Then started the zwift after it restarted and it would not find the bluetooth connection for my garmin hrm dual. WTH!? I thought it was the battery gone dead on my garmin hrm dual so i change it out. Still nothing. But the Wahoo HRM connected without issue? Can anyone help?
What do you mean by “iso MacBook”? macOS or iOS or both, the new 27? Does the Garmin HRM work with another device? If you’re using a Bluetooth connection, the new encrypted Bluetooth connection could be the cause.
I didn’t think the HRM-DUAL has firmware support for that. Digging around to see if I can find mine…
That’s right, @Paul—the HRM Dual is older. My mistake, the problem must be something else.
Another thing you can try is either re-installing the game, or deleting/moving the prefs.xml and knowndevices.xml files in Documents/Zwift to reset all of the pairing history
I had a similar issue the other day - latest MacOS, latest Zwift. I ended up pairing the HRM with my Kickr through the Wahoo app on my phone which Zwift then picked up easily enough.
I’m on Catalina so quite old now, but my DualHRM connected yesterday no issues over BLE.
W10 on my indoor setup and connected to ANT+ this morning no issue.
I would try what Paul mentioned.
Fixed it. Just bad batch of batteries from big box store. I’m guessing taking the battery out again and putting a good battery made it connect like before the update.
Might not be bad batteries; check and make sure they don’t have a child safe bitter agent that’s been applied to them, there should be an image and a label on the box mentioning it… or do the crazy thing and taste it yourself (tasted plenty of 9V’s so no idea how these compare LOL)
Those bittering agents can have detrimental affects on these batteries. A weird, but a good practice for these in particular is to clean them with isopropyl alcohol which should clean the surfaces from that coating.
Worth the try if you didn’t throw them out. (And recommended for anyone that reads this in the future).
