Hey guys, have a question on how to integrate data from Zwift / Garmin etc.
My current setup is (will list everything even if not used for indoor rides as it might be helpful to find a solution to my issue):
- KICKR Core Turbo Trainer (with power meter) - currently used.
- ZWIFT to record and train - currently used.
- HRM 600 Band (for heartbeat) - currently used.
- Garmin Edge 540 - not used during indoor rides so far.
- Garmin Forerunner 265 - used yesterday for the first time.
Usually I record my indoor ride on Zwift, which automatically imports it to Garmin Connect. I see power, bpm, cadence, KMs, average speed, everything on both Zwift (and Strava) and Garmin Connect (data are imported directly from Zwift). However, no calculation of VO2 Max has ever been recorded.
Yesterday I used the Forerunner 265 for the first time. I connected the watch to the power meter (NOT the Turbo Trainer, just the power source) and started the “indoor ride” function the same moment I started my ride on Zwift. While riding, bpm and Watts were exactly the same as I could see in the Zwift app (so power and HRM were working correctly). However, KMs, average speed, etc were all messed up and different from the actual Zwift ride. This time, however, I got a VO2 Max calculation as well (which I assumed came from the watch, as it was the first time I was using it and the first time VO2 Max appeared in Garmin Connect).
I am trying to look for the optimal setup, without having the ride recorded twice but with VO2 Max calculation / data and also accurate when it comes to KMs, average speed, etc. Can someone please help?
Marco
