I was thinking to try a Garmin Coach cycling plan for an upcoming granfondo. I have an Elite trainer, and a Garmin 840 computer.
Can I have the Garmin 840 control the trainer, and at the same time be connected to Zwift to do the workout on one of their courses? I just don’t want to do a workout watching my cycling computer.
My understanding is that if I do the activity only on Zwift then Garmin won’t recognize it as done, even if I upload it on Connect directly on Zwift
If you do not pair the Resistance tile in Zwift, it should work. Only one thing can control resistance, which should be the 840
That’s my line of thought. My idea is:
Garmin 840 controls trainer resistance and is also paired to the HRM
Zwift is paired to my Assioma pedals, to read power and cadence data. Just for visual feedback.
The only doubt I have is: can I also pair Zwift to the HRM? This would again only be useful for a visual feedback. I can still look at my heart rate frequency on the 840.
Probably yes because the 840 should read HR via ANT+ which would not use up the HRM Bluetooth connection if you want to have Zwift use that.
I haven’t done this using a Garmin but have done it recently using the wahoo app on my phone, so that I could do my workout and still get double XP in the Tour of Watopia. I connect my wahoo Kickr first using the direct connect. I then disconnect the Resistance in Zwift. I then open the wahoo app, select the work out and start. It works. I schedule my workouts in Intervals.icu and this is linked to Wahoo.
