Game Update v 1.122 [September 2026]
Well, luckily the ppl form the echo app know what they are doing, so the app works w/o any problems for like 2 years for me. Unlike my HR strap, I sometimes use, which had to be replaced once already.
I looked and see that Echo is a $20 app. For $20 you can get a chest HRM from Amazon.
Interesting, this is the first I’ve heard that it’s not supported. And I’ve been using it years, since I signed up with Zwift. And so do lots of others. And it has worked mostly with some intermittent connection problems. It has required ZC to serve as a bridge. Has there been some kind of notification that it’s not supported?
I’ve tried heartcast and found it didn’t work better than the iWatch with similar dropping issues and sometimes hard to connect. The iWatch is quite good as a heart rate monitor and very accurate. There’s no reason to not support like any other HRM.
I got updated yesterday I think and rode today. The auto connect worked really well; it could be because I left the bike and wahoo plugged in since Friday. I’m going to try to see how it works when I leave turned off to reduce ghost electricity. The iWatch worked as well which was surprising since often after an update it takes a few days to work properly. I used ZC as before with the default auto connect.
Let’s see how it goes tomorrow.
Maria
I’m not trying to persuade you to change anything, but an optical arm band (same technology as the watch) will not have the same kind of problem wearing out as a chest strap. The chest strap is the more accurate way to measure HR since it’s observing electrical impulses from your chest rather than trying to measure your pulse by shining a light through your skin somewhere farther away, but the straps wear out, the electrodes get damaged more easily by sweat, etc.
They first started telling people about dropping support for the Apple Watch in 2021. They did not remove the integration. If you contact support, I expect they will confirm that it’s not supported.
A lengthier explanation from one of their developers is here: Apple Watch not connecting? "No Signal" - #88 by Paul_Southworth
Hopefully they will continue working on it.
I posted about my connection woes following the update to 1.122 here Device Pairing Updates in Zwift [September 2026] - #20 by Erlendur_S_Th
I leveled up with an outdoor ride and I’m 99% sure I didn’t get my 50k drops bonus. Is that still an issue? I thought it was resolved some time back.
Edit: I found a photo from my last ride and I’m 100% sure I didn’t get it.
Speaking of leveling up - I was wearing the confetti socks and gave a Ride On to a rider nearby - he leveled up to Level 5 based on my 2 XP awarded to him. Or it may have been the 50 XP for the Party On badge.
Either way - I like that I was able to get that rider to the next level AND see it happen.
I’ve gotten a “this destination is no longer available” twice now (out of two times) when starting a ride with coco under 1.122 (after the successful auto-teleport completes)
Since latest update I was having disconnections during rides and workouts so I uninstalled Zwift on my Apple TV and companion on my iPhone re installed both but now Zwift will not connect or find my Tacx Neo 2T or Zwift ride or hrm . Never had this problem before this update. Getting so frustrated :weary_face:
A/my chest strap strap isnt more accurate than an Apple Watch. BUT - after the hint of @calfzilla I looked up the prize for the echo app again, and they raised the pricing too pretty much. And since u cant use the broadcast on a garmin for example, when u ride outside, it might be better getting the chest strap in that case.
Thanks Paul. I’ve had the connection problems on and off and have reached out several times about it. I don’t remember ever hearing that it wasn’t supported. It seemed that it wouldn’t work for a while and then it would. No reason wither way. Now I know that it’s the API’s not working properly. I just updated to IOS27 including iWatch and it seems to be working with 1.22 better. Or at least yesterday and today. I prefer the watch over the band since it’s more comfortable for me. I will wear a band if I have to since I like having the HRM.
I did notice today that the control pairing was back to slow even with leaving the bike plugged in. It was almost instantaneous yesterday and nothing changed since then. Finally, after several tries and clicking on the icon, selecting “all”, it finally found both controller settings. Any idea what’s going on?
One other question: is there a way to know what the gear ratios are for chain ring and cassette? It simply says “Gear 1 X” or “Gear 2 Y” not 50 X 28, etc…
Maria
That’s determined by these settings:
Paul,
My question is different. I do understand the settings. I don’t see a way to display the gear ratios when riding other than “Gear 1 X” instead of “50X28” as we see on bike computer. Seeing “Gear 1 X” is simply not very helpful as I don’t know what the gear ratios are that I have available other than what the overall range in the settings.
Maria
Thanks to autopairing not working I missed the start of my event last week faffing with HRM.
I don’t know about anyone elses workflow, but i will fire up the PC, check/install updates (if first time usage that week) and then fire up Zwift and pair the ride/kickr. Then i will go and get ready and come back with my HRM..which of course has not autopaired.
Thankfully there is still the option to turn the pairing screen back on. Please do not consider removing it…
The gear number is all you get from Zwift.
Why? the info provided says it’s same as standard gear ratios….
Sorry I have no idea. That’s how they did it. Same for other smart bikes that have a gear display that predates all the Zwift hardware.
But does it actually matter? If a gear feels too easy, shift to a harder one. If a gear feels too hard, shift to an easier one. Does it really matter what the gear ratio is?
Neo bike gives actual gear ratios and you can customize them as well. Double or triple up front and up to 12 in back, all whatever numbers you want (within a certain range). Shame Zwift went with just 1-25
