I saw fireworks as I was on Tempus Fugit heading from the old mining town towards Downtown. They were way off in the distance, probably around the pier.
Maybe a temporary addition for the USA 250th?
I have seen a few other of instances like that, but can’t really put my finger on where right now.
The key is that the leg of the arch is well off the road on the side that does go through the arch, whereas the other leg is in the road.
Starting one or two updates ago, with Apple TV, I see a noticeable delay before active events show up as available for selection. This has caused me to almost miss a few of my scheduled group rides because the Events section is completely blank. After several minutes it eventually populates and then I can navigate my way to select my ride. This was never an issue in the past.
For me this update broke the route of the week tile. Opening it would cause zwift to hang. I had to delete the Zwift AppData directory to make it work again. I’m also getting a lot of spam with zwift failing to create the appdata directory since this update (which causes the log file to blow up massively to hundreds of thousands of lines, but does not seem to affect anything otherwise).
could Zwift please add more Colnagos to the drop shop? Tadej Pogacar is winning the TdFs on the Y1RS and Vr5s and it seems wrong to have the only Colnago available in the shop a Vr3 from 2021. A famous brand with lots of history and nostalgia and greatly underrepresented.
Colnago is a marketing partner of MyWhoosh so my guess is there is basically no chance of further arrangements with Zwift. I have no inside information about that but I don’t see it happening.
Tour magazine and the Nero boys don’t recon the Factor one is the fastest available btw. I think factors also sent a custom 1x build to the test to save a couple grams of drag.
I would guess none of them have ridden the Bugatti version (I suspect neither JC or CM have AUD$40K to drop on a limited edition rare frame). It’s a bit different to the normal version with a different fork and other changes - so it is UCI illegal.
I doubt the coaching business and the Sydney IRL bike racing scene makes enough $$$ to afford one of those.
There is also still the issue of hand bikes and recumbent bikes being seen in races, but not chosen. This leads to no draft for other riders,.. difficult for 5v5 club ladder
Club Ladder could choose to forbid it. I have not searched the rules about this but nothing stops them from saying they will DQ a rider for using a handbike if they think that makes sense.
