I’m on 112 and certainly don’t have that scaling issue on a W11 laptop hooked up to a 32" TV. As well as the main header I think I see three rows of ‘cards’ that show four or five cards each horizontally. Yes, they could be smaller, but given people could be much further back from the screen it’s understandable.
This sort of thing is often slowly rolled out with server side flags in case it’s broken or just awful. In this case it’s awful so hopefully they’ll revert to what it’s been and then work to go back to what it was a couple of years ago, but we all know better than that.
Just got this in the middle of my ride. Fortunately it didn’t drop me from my ride when I clicked not now.
Maybe a glitch related to the subscription system update yesterday? ![]()
Same here, as did several other riders in the pacer group I was riding with.
@Al_Sherman and others have commented to me about having seen this type of dialog this morning. I hadn’t seen it on the PC, but this is perhaps related to the billing platform updates yesterday.
This is my Zwift on a 43" TV:
I wonder if it’s a setting on your TV that is causing your issue, something that Zwift have done (possibly in relation to a setting on the TV), or if the small difference in our TV sizes really makes that much of a difference. ![]()
I have a similar home screen to the previous poster. It’s scaled way too big - 49" TV.
Your screen isn’t the same - check the details of the Challenges tiles, particularly the bottom of them.
It appears there’s some sort of home screen update rolling out, which is why we don’t all see the same thing.
I think this is the correct explanation for people seeing different home screen tile scaling:
Almost certainly for two reasons:
- The shapes of the tiles are different, this isn’t just some scaling thing (notice sharper corners on the challenge corners on the new version)
- It was me who said this is what’s happening
Yes. Or you can move it left or right.
That isn’t the new setup yet.
hi, since the latest update my laptop can not start Zwift. I have tried everything possible: upgraded my RAM to 8GB, performed a clean install of Windows 11, installed DirectX runtime, rolled back to older Intel DCH drivers, and even tried the ‘Windows KB Workaround’ in the Launcher’s Debug menu, but no solution. Reading cause of the crash from the game logs, shows a failure in the OpenGL shader compilation on Intel HD graphics: [10:09:50] ERROR: [GFX]: shaderInfoLog: ERROR: 0:340: ‘samplerCubeShadow’ : syntax error syntax error [10:09:50] [GFX]: loading shader hardsurface[0][0].4 failed!
Since cca 10 days the patches have made the game fundamentally broken and completely unplayable on the previously supported hardware, and neither workarounds nor basic support steps resolve it. My condiguration is a 7thgeb Intel I3 cpu, 8gb ram and intel hd620 gpu. Please help!
your GPU uses system memory too, so maybe this is still a limiting factor? That chip was launched in 2016, so you’re talking a 10 year old system now… might be time for an upgrade? If you are using a PC, there are many low cost options on Ebay for instance that will give you a better experience. Potential to also get a dedicated GPU and future proof yourself a bit more.
hi Mike, even that 10 years old gpu was working fine on the highest resolution of the game 10 days ago. i do not think it makes sense to change my laptop, i rather would have the software issue get fixed
well that’s probably debatable ![]()
contact support and they can look at your logs to see if its a larger issue or not
