Game update v 1.100 [October 2025]
Maybe? Not sure what is meant by ‘direct connect’ as both my trainer and Apple TV are on wifi.
I switched to Bluetooth and it’s ok, the JetBlack victory will bridge my heart monitor across its connection. But it has ‘race mode’ in wifi and I’d sooner use that. When they fix it.
Trainer connections via wifi use the same “Direct Connect” protocol as cabled trainer connections.
Is this my phone or is this the App. The font is oversized (Weekly Goals)
It’s a known app problem. Zwift are aware.
I can confirm that this issue only happens on the pairing screen. I’ve been riding every day and ignoring the blinking connect/disconnect since I updated to v1.100 and during the rides there were no disconnects as far as I can tell.
Sorry if mentioned. Since update, zwift on ATV not remembering my devices when connecting. I connect devices through phone. I can reconnect everything fine.
I had the same problem. For me it was that the HRM 200 was set to “secure” mode instead of “open” mode, meaning it only show heart rate on Garmin devices for some reason. Toggle to “open” mode and it started to work. You can switch between open and secure mode on HRM 200 by double clicking the button on the sensor. See Garmin HRM 200 manual for more details.
Johan - Thank you. I did find that feature, now need to figure out how to get my older HRM to connect
Does your older HRM-DUAL pair successfully with anything or can you see it with a Bluetooth scanner like nrfconnect or Bluetooth Inspector?
