@shooj What time does New York expansion officially kick off?
Probably 0900 Pacific Daylight Time.
I live in CDT, and Stage 4 events show up at 1100, which is 0900 PDT.
The first event is 12:00 est but I think it will open one hour prior.
Anyone else getting flashing black boxes/assets? I haven’t seen these before, so maybe just an issue on my end of things. Or perhaps an early Halloween haunted ride. Only happened on Sugar Cookie between Stoneway and Acropolis sprints.
I’m also seeing the oscillation between Connected and Connecting on my JetBlack Victory, so I’m guessing this display glitch affects all devices using a network (WiFi or ethernet) connection and not just the Wahoo devices. As suggested, I had zero issues once I continued into the game.
I am sad to say I have been hit with the wifi disconnect, I stopped for a bathroom break on route of the week about 20min ago and came back to a connection disconnect. Trainer suck on connecting, had to unplug my Core V2, and reconnect. Trainer reconnected but still didn’t work, in Zwift I had to disconnect and reconnect and finally got it to continue riding, only problem was I had NO virtual shifting. Turned off an on play controllers and nothing,..virtual gears work, but stuck in what felt like the last gear I used.
Same here, on apple Tv with .100
After about a 1.5hr break, happened again on the 11am mtn Stage 4 unlocked but with no virtual shifting. Restarted trainer and playing controllers 3 times and on the 3rd time finally worked.
what icons are you referring to?
I’m seeing the same thing with my Kickr Bike (latest fw) since the update - flashing connections but the ride itself seems to have no issues.
Next to Volcano and I don’t think the tropy icon was black before, it was orange or yellow?
oh yes, I noticed some strange colors up there on my ride today too, must be a bug.
I’m seeing emojis fine in chat as well as the rider list. ATV tvOS 26, 1.100.
Thanks for reporting! This issue will be fixed in 1.101.0.
The escalator/accelerator stuff renders weird when approaching from a distance, starts off with just a sliver visible and slowly fills in. Happened repeatedly so it’s not just a one-off.
looks like there is a shadow blocking it from the surrounding buildings, but there shouldn’t be any shadows in that spot
Thanks for the report @calfzilla , this one will be fixed in 1.101.0
I am having the same issue when connecting via Ethernet. Switched to Bluetooth connection and all is fine
@shooj Garmin HRM 200 pairs but shows 0 bpm with the latest update
4iiii HRM and Garmin dual HRM wont pair at all. Any suggestions or help. Thanks
