Game Update 1.125 [November 2026]
I had the update download today, was able to set up the watt lock buttons.
I tried watt lock today on my ride today and it kept resetting back to gear 8 :frowning:
I’m using iPhone 17 Pro Max and not noticing the phone heating up.
Are any other apps running at the same time? I usually have only Companion App and Safari running.
I lost bluetooth connection after last update. Funny enough when i go run mode i can pair hrm. But nothing in ride mode.
Good morning, my Zwift on Windows still hasn’t updated to 1.125 for some reason, tried clicking Check for Update with the taskbar icon too. Any suggestions on forcing the update so I can try the new features?
@Jeff_Hallock … The phased rollout is ongoing and will complete today. You should get the update later today. I’d contact support (on Friday) if this has not happened for you.
Edit: sorry missed your question slightly… I’ve not tried forcing updates personally so not the best to give advice. I think some have seen results by deleting and re-installing Zwift (but I could be wrong on that)… If I were you, I’d wait it out :+1:
Zwift uses a phased rollout, if you typically receive updates on Thursdays, you will always receive updates on Thursdays.
You cannot change or force updates, this is just how they operate.
Thanks for the insight Jon, I did read that it could take 2-3 days but wanted to make sure. Curious how they decide who gets it first vs last. :grin:
It is a random selection of each device type, based on the device identifier (ie, not your account or location). PC and Mac are generally done first since there is no delay for app store approvals or distribution. So let’s say you have two PCs, you might find one gets the update and the other does not.
Yeah, it’s a thing. I have tried deleting and reinstalling with mixed results…
Yes I had a couple of apps open. I closed all and turned iPhone 13 off and on again. Opened apps one at a time and narrowed it down to companion app. This is the first time in years that the phone has heated up using Zwift. I’ll keep on eye on it as I continue to ride this week.
I’m a little confused by your report since you are talking about both Zwift and the Companion app, on one phone? Can you clarify that? Those two apps can’t run on the same device at the same time.
Exactly the same issue for me following the update. I can see the wifi option in the pairing screen, but the power source just says “connecting…” I tried rebooting and reloading Zwift, deleting the known devices file, but never able to connect by wifi/lan. In the end, resorted to BT which seemed to be ok, but I’d like to understand why wifi failed after the update. Kicr bike v2 and W10 PC. Latest software updates etc. Also no issues connecting to the Wahoo app by wifi which confirmed the bike is transmitting wifi as normal.
Everyone including @Jeff_Hallock please update to version 1.125 at your earliest convenience.
@Od_Avinu and @V.Ampiro_del_Mar Thanks both for flagging this up.
When is the last time you rebooted your WiFi router? If you can’t remember - please power off / on the router. Then power cycle your trainer/DirCon adapter dongle if you’re using one, followed by the computer you’re using to Zwift. This is the first thing to do in troubleshooting DirectConnect flakiness.
Thanks for responding. As it happens, I’ve done a full router/wifi reboot in the last 2 weeks (usually every couple of months). My PC and trainer are switched off between rides (direct WiFi connection, no dongle).
I’m going to repeat the whole exercise (WiFi/ router reset, machine/ software reset etc) including reinstalling Zwift and will report back.
I’m running Zwift on a windows 10 machine and have the Zwift companion app open on my phone. The phone is overheating with the companion app is running. I’ve been using this configuration for years with no issues. I’ll have another session tonight and will see if the problem persists.
Patrick
@shooj router was rebootet 1h before error occured.
Could you please investigate in polar verity sense issue? Had to buy wahoo tickr fit, because polar doesnt connect reliable bt/ant any more. Polar works fine outdoors with garmin 1040.
My dircon is faulty. another dircon works fine. Todays ride without problems.
I am on the latest version 1.125 on Mac OS and this does not work - still reverts to gear 8.
I noticed this, too. I even tried it several times and it always went back to the default gear setting.
same here ,
Since the last update, I can only connect via the Companion app. The Zwift app on my Apple TV fails to detect my trainer and heart rate monitor—the Bluetooth icon just keeps spinning. Furthermore, if I disconnect the Companion app during a ride, my avatar simply stops the ride.
