Hello Zwifters
Phased release of game version 1.125 begins today on macOS / Windows / Android devices.
Phased release to tvOS / iOS devices begins tomorrow.
Watt Lock now restores your previous gear when disengaged.
In the event of a game crash, after re-opening Zwift, a recovery prompt will show allowing Zwifters to publish their interrupted activity to all of their connected third-party platforms. This feature is currently in effect for rides greater than 2 km and at least 10 minutes in length.
Locked campaign stages now show their start time within the campaign screen. Know the hour you can begin riding the next stage to ensure your rides count towards your progress.
Fixed an issue that could cause some activities in Watopia from appearing in the activity feed or in 3rd-party services.
Fixed an issue that could cause mini-map route progress to not update for the Volcano Circuit or Volcano Circuit CCW routes in Watopia.
Fixed a potential crash that could occur when using Garmin HRM 200 and HRM 600 heart rate monitors.
Fixed an issue that could potentially cause Zwifters using Coffee Stop to accelerate ahead of their group.
Android
Reduced the amount of time it takes to launch Zwift after a game update.
UPDATE November 3
NEW: You can now pre-download Zwift Video routes ahead of your ride. Jump in and try this new Zwift Plus feature before open access ends November 9th.
UPDATE November 4
Phased rollout to macOS / Windows / Android continues.
Phased rollout to iOS / tvOS has begun.
UPDATE November 5
Phased rollout is complete to all OS platforms.
Do you have questions or issues to report? Let us know below
I’ve seen that one for a long time. I distinctly remember one shortly after the NYC expansion with a Coffee Stop rider accellerating off the front of the pack on the Brooklyn Bridge KOM, about 15 seconds in front when the coffee stop ended.
Great that Watt Lock now remembers what gear you were previously in, really handy. Has the similar issue in Workouts when starting a free ride block been addressed? Where you have a block at set watts then start a free ride block, to be able to do a max effect etc., your virtual gears used to be reset each time. Basically stopped you from doing this. Haven’t tested this for ages, just stopped doing these workouts.
Which pairing options do you see for the Kickr? If you see a WiFi option on the pairing screen, that is the Direct Connect ethernet connection.
This sounds like the issue caused by Polar firmware changes. The HRM has Bluetooth encryption enabled and therefore does not send any HR data to Zwift. It’s discussed in this topic:
@Paul: I am aware of that threat. Zwift has and is doing BT stuff on its own (e.g. Zwift Play). My hope is, that they may look into it and are able to handle encrypted BT connections to get that rock solid device (polar verity sense) back.
Yes, I only want to connect my Kickr via Wifi. But top left Icon (power source) does not pair properly Kirckr over Wifi found, but blue Icon with “connection lost”. Top right Icon (resistance) remains orange, meaning Kickr over Wifi not visible.
I did some forth and back today, it seems the direct connect module itself had some issues. use my gf dircon module without problems.
I updated to 1.125 tonight and after the update tonight my iPhone got extremely warm while using Zwift Companion App. I closed out all the apps I was using and turned the phone off and let it cool. Started it back up again and open all apps except Zwift. Phone was fine. Then opened Zwift and it begin to get very warm to the touch again. Anyone experience this issue. It was the first time I have had the phone heat up using the companion app. I was riding on the new Molten Momentum route.
