Hi!
I have two questions.
- I created a few workouts of my own. Will they be subject to changes in my FTP?
- How long duration must the climb portion of a climb portal event be to increase the FTP?
Kind regards!
P Zwiftsson
Hi!
Kind regards!
P Zwiftsson
Depends where you created them. If you created within Zwift they are most likely to be based on % of FTP and will change when your FTP changes.
Zwift can detect a change in FTP on any effort over 8 minutes. You should decide whether you want your FTP based on a short (8 min), medium (20 min) or long (60min) duration. Have you thought about just doing The Grade FTP test or Zwift’s 20 minute standard FTP test.
Thanks a lot!
I usually stick to the ordinary FTP Ramp Test for larger/experienced riders. I created the workouts inside zwift and an interesting thing is that ie a climb portal ride >8 min may affect the FTP which in turn affects my workout zones.![]()
It would affect your next workout if you get an FTP increase (assuming the workout power targets are %FTP) but if for some reason you don’t want that, you can set your FTP back to whatever it was before the increase.
Thanks. That’s a clever way to do it.![]()
