The website says: t the end of the test, Zwift will display the option to update the FTP value on your profile with the one from the test. It didn’t do this for me. I don’t even know how to see my FTP value. What do I do now?
Rachel,
You can set your FTP in your profile (see the article below); What I don’t know is if the test is lower than your current FTP value if it resets it to the lower value.
https://support.zwift.com/hc/en-us/articles/206438003-User-Profile-Age-Weight-FTP-
If your ftp is lower it won’t update the value.
“If your ftp is lower it won’t update the value.”
I’m sure this isn’t true. Last year, I tested while I was feeling far less than 100% (recovering from a cold) and my FTP ended up being 2 W lower than the previous test. My value was adjusted (lower) automatically and I had to reset it to the previous level manually.
To the OP: Did you fully complete the FTP test and save your ride at the end?
