Can you add extra miles on to the end of a race? Actually, I want to add extra time.
The WBR 1 lap flat route seems be a great motivation for a FTP test but 1 flat lap is less than 20 min.
Can I just keep going to complete 20 min?
I’m going to find out on my next off day but I thought I would ask.
Also, if I lower my current FTP in the settings, will my new effort during the race up date my FTP(if greater) or does the program follow my historical best even if it was back in Spring.
I want to see what all this real world riding has done to my FTP.
If you outperform your current FTP significantly, you should be asked if you’d like to update your FTP. The update shouldn’t be based on historical numbers; it should be based on your current FTP. If you’d like to force an FTP update, you can lower it significantly prior to your ride.
However (and that’s a pretty big however), the updated FTP probably won’t be anywhere near as good a measurement for comparison against other cyclists. FTP as a metric depends on a similar (ideally identical) warmup period prior to the test, so for best results we recommend taking one of the included FTP tests.
