Front support bar
This morning I posted about how stiff the flywheels on my jetblack victory and I’ve since noticed an issue, as something that’s meant to be stable, there’s a difference of over 2” on the front support bar from screw to the end is that intentionally like that
I suspect if you ask them about that difference you’ll hear that it’s intentionally asymmetrical, intended to be longer on the drive side.
Strapping it to a rocker board, using sand bags, or bolting it to the floor are all strategies people use to prevent the trainer from moving. Higher end trainers are also designed for better stability but that’s a cheap one.
Fair comment, thanks for your reply
