Front mount for rockerplate
seems like it would be easy to print a front mount that would fit most rocker plates.Does anyone have a printer and want to attempt it? Seems like it could replace the riser then have a flat plate with holes to insert bolts…
Do you feel like you need a mount? I’ve used a Ride with my MP1 Nfinity for around 18 months with no issue.
No issues but it couldn’t hurt to put a mount on.
The foot on the Ride frame is attached with bolts. In theory you could drill holes in the rocker plate to match the bolt locations, get some longer bolts with washers, screw them in from the under side of the rocker plate.
Not sure why that would be necessary but if you feel it is then that’s a pretty easy job.
