Fitbit Aria 2 weight Scale and Withings scale not syncing
Look at it from the positive side. You no longer have to wait for a low gravity day for weighing yourself :grinning:. But yes. I bought my whitings to auto set my weight. Really looked forward to the morning weigh ins. More on those low gravity days, but still.
+1 please. This has been broken for months now…please fix. Its the only reason I bought my Withings scale
Another +1 here. This should really be an easy one to fix.
Another Vote from me. If you break it, mend it!
Yep, I want this fixed too. It’s the main reason I bought my Withings scale.
At the time I bought it, I didn’t even realise it didn’t work. I checked once after connecting the first time and things looked great, so I haven’t even bothered to check. But now I see it’s clearly not working, going by my ZwiftPower profile.
Same issue here. We are too hard on zwift, we should give them more time and not pressure them. Only 120 days have passed since the sync failure:p
+1 for a fix for this. Withings scales working perfectly apart from the link to Zwift it would seem!
Fix please
+1
Post must be at least 8 characters.
Withings scale used to work and now it doesn’t.
Please fix, thanks
- unloyal customer.
I’m struggling to believe the last patch list included moving rim brakes to the hub, but this feature can’t be fixed? A lot of us being very accurate and honest with our weights, just by standing on the scales, but it’s not transferred over?!
Fix please!
Fix please
If I have a set of scales that I bought specifically for the weight sync, and I have my account set up correctly within Zwift… then it’s not my fault if I set my weight at 60kg on the assumption that the system will keep it up to date, is it? :smiley:
(I’m only actually running about 2kg light at the moment, so not a big deal.)
Me too. Please fix the problem soon. Thank you!
I would also like this to be fixed. I bought a withings scale because of this sync!!
Thank you!
Please fix this problem soon. Fitbit and withings does not work. it’s best to add the weight to the garmin connection. :+1:
