+1 for this. Also experiencing this issue.
+1 for me too
Iâve having the same issue with my Withings âsmartâ scale. Itâs a pitty now Iâm losing weight, that I canât see automated to Zwift.
Any chances to be solved soon?
+1 same issue
+1
Syncing between Withings scale and Zwift is KO since a few weeks.
Works only once when you establish the connection between Zwift and Withings.
Can someone from Zwift deal with this issue and tell when itâs gonna be fixed ?
+1
Reported to Withings as well, Strava and others. For what itâs worth, Training Peaks works well and quick. Withings recently changed API and upgraded the OAuth to 2.0. Thatâs when the issues started. Maybe thatâll be a good start.
I must say I miss the auto update from Withings.
It still woks perfectly with all my other devices, it is only Zwift that donât get the data.
If you look up a bit you will see Shooj said they are working on it.
Letâs not forget the original poster and his problem with the Fitbit Aria 2 weight scale, not the Withings scale. Although his wife says he will soon need two scales to weigh himself given his high degree of unabridged weekend beer consumption, I suspect he still wants to get his Fitbit Aria 2 problem solved so he does not have to go out and buy a Withings scale just to get this functionality again. Just a little reminder. Cheers!
How about it Zwift? Any update on an ETA for this fix?
Still issue synching with Withings
Is there any update on this now itâs been a bug since the last update?
@Gordon.S
Itâs on our to-do list, but itâs lower on that list because it doesnât break the game, and those types of bugs get higher priority.;
We ask that you manually adjust your weight in your profile in the meantime. Sorry for the news, but we wanted to let you know why itâs not been done yet.
Thatâs pretty poor response to a bug that you introduced. Itâs not like you rolled out a new feature that was somehow buggy. You actually rolled out and update and broke and existing feature.
In any other software company that change would be backed out or fixed forward not leaving customers waiting 3 months with no eta for what seems like a simple thing to fix if you actually spent some time looking at it.
So yet another feature that no longer works.
Sorry but we all pay to use Zwift it unacceptable that even though you know about this problem you just reply with oh well never mind it doesnât break the game so we wonât look at it. If you tested your updates properly before rolling them out then there would be fewer game breaking bugs to fix. I bought my scales to keep my weight in game up to date yet more money wasted on Zwift.
I bought a smart scale for the sole purpose of synching my weight to Zwift / zwiftpower. Pretty disappointing response from Zwift - if youâre not going to support this then you should remove the connections to Withings et al
Adding myself here to track the issue. I have the same issue with my Withings scale. I only noticed when I looked at ZP and saw the same weight for 3 weeks in a row. Disconnected and reconnected and got one update and now itâs back to not updating Zwift.
Still donât work. The work around described above to enter the weight manually is not satisfactory when you canât enter decimals.
When you break an existing feature in a release that, appearantly, many users use and appreciate, you are supposed to fix it.
Another one having the same issue. Hoping it gets fixed. Iâm actively losing weight and expect to continue to do so now that Iâm zwifting regularly. Would be awesome if the weight updated automatically from Withings.
Same here ⊠canât be that complex to fix, surely?
