It’s a cool app. Beats a trainer . But the effort required seems more than the real world. Maybe my set up is wrong but it’s not a positive experience tonride for an hour and see 20kph average recorded after working very hard
I think you should post your setup and maybe sone can help you in setting it up correctly so you can have a positive experience.
@John: you’re using the “Not Listed” trainer virtual power option. This is designed as a preview option for Zwift and won’t give accurate readings. If you want to get accurate readings from Zwift, you’ll need to either pair a power meter or use a supported zPower trainer (see the bottom of this list).
