Hi ive just installed favero assioma shi duo to my zwift ride and done a quick spin to see if my watts had changed compared to using kickr core v2 as power
I would usually average about 165watts over 1 hour even though the kickr core v2 was showing low watts my quick spin today showed this.
As these watts seem high iam not sure if have set the favero assioma shi duo pedals in the app correctly
If you want to compare the trainer to the pedals, you need to dual record a single activity with power measured from both devices. Here’s one way of doing that:
Make sure to calibrate them and all the settings are correct. I think crank length is one of the options. Also, i believe there is a required torque needed for install that should be in the manual.
One thing is to make sure the crank length matches your bike.
Also calibrate them:
Search for calibration on that page.
I have these pedals on my kickr bike and no issues with high power readings, if anything they read a little less than the kickr bike. But both match pretty closely the power meters on my two real life bikes.
In the Favero app, go to Settings / “Compatibility with other apps”. Double check that that is set to “Unified Channel L” Then check crank length and torque as above.
