Favero Assioma Duo not detected after Zwift update 1.123.0
I actually already solved this, just posting here in case someone else is banging their head. Running on Windows 11. There was a Windows update after my previous ride 10/18/26 that I forgot about. Zwift updated today before my ride, but my Favero Assioma Duo’s wouldn’t show up in the Power Source Bluetooth list. I could see them on ANT+, but I’ve never connected them that way. Turns out the Windows update had somehow turned on automatic backup and sync of the Documents folder and everything in it. This redirected Documents to the OneDrive folder. I didn’t know OneDrive was even enabled on that PC - I had to “show hidden folders” to see it. Zwift keeps some device setup information in Documents\Zwift, so the OneDrive redirect totally confused Zwift. Zwift couldn’t find the Assioma’s on Bluetooth. Turning off the Windows backup, and redirecting the Documents folder to the local drive instead of OneDrive solved the problem.
On Windows, Zwift does not use the Documents folder anymore, but it may look there to migrate data to the new local app data location. So once all of your stuff ends up in %LocalAppData%\Zwift you can delete the old Documents\Zwift folder.
This change came with the Zwift launcher version 1.1.15 in February, though you may not have installed that version at the time since it was not a forced update.
