I am new to Zwift and after a few weeks there are a couple of things that I think could be improved. I am using a Win 10 PC and a Tacx Flux.
Unable to change settings before commencing a ride. Presently you have to be in the game before the “Menu” option is available. It would be nice if you could make these changes before riding.
Linked to #1, I made a change to the trainer resistance under settings but not only did it not apply, I had no resistance been applied to the trainer at all. Big chainring at 7% isn’t quite right. I had to leave Zwift and enter again fresh before the changes were applied.
3.When I have finished a course I have to save it and be forced to leave Zwift. It would be good if you could save a ride and remain in Zwift so that if I want to do a different course or workout I can do so without having to leave. This would save time and keep people in the game longer. Once you’re out of the game you’re out.
- On screen location map option. An option to replace the leaderboard with a course map showing where you are would be beneficial. When riding, you are often presented with 2 options to turn or go straight ahead. If you’re not familiar with the courses and where you are on the course, these options are meaningless. If there is a course map (Waiopia being the key one) you could make a more informed choice as to whether to turn or not. Having the option to replace the left hand segment leader boards could accommodate this.
