False high wattage reading - no way I hit 1400watts
(Jeff Schmitz) #1
While on a Hard attack I was approaching 800 watts but did not look at wattage again.  After dropping I started receiving accolades for clearing 800 Watts.  Then immediately afterwards for clearing 900 Watts up to 1400 Watts.  Upon examining my end of ride and strava data I did not clear 800 Watts.
I am on a Kickr with cadence and not sure what happened unless I hit a high output for a millisecond. (doubt it)  I received a ton of points for the real or perceived effort.
Anyone else having the same issue?
(Michael Henasey) #2
somethings wrong with the KICKR.
i’ve had a somewhat similar experience a couple of times.
it’s always happened when I first pedal from a complete stop. the wattage will go from 0 to 1000+ instantly and my avatar goes from 0 to 30mph instantly.
(Darren Linkin (True 2.5)) #3
This happened to me on a ‘dumb’ trainer (with a powermeter)…went from 500 to 1200 (higher?) giving me all those awards while I watched barely pedaling.
