Failed the file checksum test
Hi
After running the installer , the downloader gets stuck and doesnt letme run zwift
it keeps on repeating a similar log
[20:44:03 2025-11-30]
Downloader: ERROR: “data\Noesis\Blend_Data\Images\Routes\card_route_greatestlondonflat_1024.jpg” completed download successfully, but failed the file checksum test (manifest=-1093833182, local=-1844390226)!
Downloader: WARNING: “data\Noesis\Blend_Data\Images\Routes\card_route_greatestlondonflat_1024.jpg” failed to download with code: 0!
[20:44:03 2025-11-30] Downloader: Attempting to try again downloading “data\Noesis\Blend_Data\Images\Routes\card_route_greatestlondonflat_1024.jpg”
[20:44:03 2025-11-30] Launcher: DoUpdateCheck() Called.
[20:44:03 2025-11-30] Launcher: ZwiftApp.exe is not running.
What happens if you follow this process:
Hi @Too_Many_Kebabz, welcome to the Forums! I’m Francisco from Zwift Support.
That “failed the file checksum test” message usually pops up when Zwift finds something off with the game files; often due to a corrupted install, an interrupted update, or a hiccup during download.
The quickest fix is usually a clean reinstall, just like Paul mentioned. Grab a fresh installer from zwift.com/download and follow the steps in the article above.
If it still gives you trouble, don’t hesitate to open a support ticket so we can dig in further.
Ride On.
