As I wrote earlier my events calender is not working properly. For September I see too few events as usual. Who can help? Zwift does not reply so what’s going on ?
Niels
Right now there is more or less 4000 scheduled events in the calendar because Zwift have scheduled a lot of Zwift Academy events (roughly 2200). That means that there is the same number of regular events as usual. Edit: I base this on the event list at ZwiftHacks.
As it was said in the other thread you raised about the same issue, most recurring events only appear in the schedule a week or so before they take place.
If your problem is that you cannot see them in ZCA, check your filters. Even if they look OK it could be a problem with them, particularly after a ZCA update - it has been seen before. First apply a new filter and then reset it.
Also, if your problem is that you are trying to see them in ZCA in the first place, try using ZwiftHacks instead… Events
Are you looking in the game screen? There’s a toggle to switch the Zwift academy on and off.
