Event Description screen in events [May 2024]
My sister can’t join events without the Event Description covering the right side of the screen. It just started showing up recently, and it’s never happened before. She’s at level 62. It’s hiding the people you’re zwifting with and the mini-map.
There is an arrow to close it, but the game crashes when she clicks on it. The game also crashes if she tries to use a power-up by clicking on it. She can use power-ups if she uses the companion app. As long as she doesn’t try to do anything on the screen, she can ride, but it’s annoying not to be able to see rider stats.
She is on a PC (Windows 11 version 22h2), and Zwift version 1.65.0.
Any idea what can be done to get rid of it?
Hi @Nancy_Giovannini_TT1 , thank you for the report! The fix for this issue is being implemented in a coming release. In the meantime, your sister should be able to avoid this issue by clicking on “Start Ride” only once to join an event. This issue seems to only occur when the event description is opened rapidly after selecting “Start Ride.”
Hi Rowdy,
Thanks so much for your help. I really appreciate it. :smiley:
Nancy
