Error: "X3DAudio1_7.dll is missing or not found"
If you see this message: “X3DAudio1_7.dll is missing or not found” it is likely that the DirectX install did not occur successfully.
If you run “C:\Program Files (x86)\Zwift\dxwebsetup.exe” it should install the correct files and you are off and Riding!
note: “C:\Program Files (x86)\Zwift\dxwebsetup.exe” is the most likely/common directory. If this is not correct for your individual install, simply navigate to the folder where Zwift was installed on your PC and you will find the dxwebsetup.exe program.
Thank you for sharing this! :slight_smile:
I got the same thing on my older laptop. Tried to install again and it did not work. I guess all my riding will be in the living room on my desktop. That is what took me a few days to get on. Need a USB extension cable.
