Hi!
Wahoo Kickr here. Over the last several structured workouts, ERG mode hasn’t been able to hold a stable target power - it fluctuates significantly above and below target, which wasn’t happening before. Comparing two workout reports:
- November 2025 (“Endurance #1”): power distribution tightly concentrated around the target
- Recent (“Sweet Spot Foundation”): power distribution much more spread out
Already tried, none of it fixed it:
- Updated Kickr firmware via the Wahoo app
- Full spindown/calibration via the Wahoo app (redone after the firmware update)
- Fixed neutral gear throughout, no shifting
- Enabled ERG mode smoothing in the Wahoo app
Since nothing helped and it’s consistent across multiple recent workouts, it feels like something changed on the Zwift side recently rather than a trainer-specific problem. Anyone else seeing this lately, and is it the same root cause as the other recent threads? Screenshots attached for comparison.
Thanks!
looks like you turned ERG mode power smoothing off in the wahoo app.
Hi! Thanks for your response, ERG smoothing is on in the Wahoo app
it looks like the setting isn’t working, maybe try toggling it off and on a few times?
For what it’s worth: the second graph is a much more accurate representation of your power output. Not as ‘clean,’ perhaps, but more accurate.
Unless the trainer is having connectivity problems to the device running Zwift, it simply trusts the power numbers sent by the trainer and shows whatever it gets.
I might have suggestions for things to investigate if you share the trainer model (“Kickr” is not specific) and what you’re running the game on. With ERG mode smoothing on, I would have expected a somewhat smoother looking graph than that, but the physical gear size you are in can also affect it since that affects the flywheel speed of the trainer. Sometimes putting it in a bigger gear can help.
Not saying this is also causing this for you but I had a similar effect with my Kickr (v5) when it developed mechanical vibrations. When I tightened the screw that fixes the axle the flywheel is sitting on the vibrations went away and erg mode smoothing was back to normal.
Hi @Paul_Southworth, My trainer model is the Wahoo KICKR CORE (not the v2) and I’m running Zwift on a Windows pc. The behaviour is the same with other windows pc’s and also trying with an IOS device.
Hi @Magnus_Kreth, I think the problem has to be related to communication/software but I will check it anyway, thanks!
If you want to check for communication problems with the trainer, go to a PC where you did a workout and upload a log file to trainerdx.com. I’m doubtful this is the problem but it is easy to check. There is a Share button on the log report you can use to make it public, grab the link, and post it here.
What gearing are you using on the bike when this is happening? What size chainring, how many teeth on the cog? Do you have large/small chainring options on the bike?
