ERG mode turning off during rides drifting/stop pedaling
Hi, I’m having a problem which I can’t believe I didn’t find when searching the forums.
When you’re Zwifting you sometimes want to stand up during your longer sessions as you are probably aware of to relieve some of the discomfort. However, when you’re standing the pedaling stroke get’s uneven, which is kind of unavoidable when you’re going ERG and light watts. Sometimes when I do this, the ERG switches off and it’s kind of annoying to turn on again. It’s like I pull up the menu, turn on ERG again, but it takes 10-15 seconds or something.
My question is if there is a way to turn off this auto-switching when your pedaling slows down, or whatever is happening.
If you’re in erg mode, I’m guessing you’re doing a structured workout? If so, what you are experiencing is by design, and can’t be turned off. It’s there so that if you ‘poop out’ during the workout you don’t end up stuck in erg mode, and unable to pedal
If you want/need to take a break during a workout, I’d say the best option is to pull up the ride menu, and then hit the ‘pause icon. And when you’re ready to again, hit the ‘resume/play’ icon.
Do you use the Companion app? That might make access to the pause button or the ERG mode on/off button more convenient.
Ok, I guess that makes sense. But I don’t understand why it has to be so sensitive? It’s kind of hard to determine when it happens. Because sometimes when I stand up and pedal, it doesn’t happen, it’s only in a specific pedaling pattern or something. But I guess I’ll have to live with it.
