I did the v1.124 update today (macos Tahoe 26.6.2) and my power isn’t changed by the Workout despite the ERG mode enabled.
I read about the Watt Lock feature and thought it was about it, but I don’t have the lock icon on the toolbar.
If I shift gears on my bike I manage to have an highest power for a short moment until ERG mode or something make it drop to the previous power (again I don’t know about Watt Lock being enabled or not since the icon isn’t there).
Hi there, first of all watt lock won’t be available while in workout mode, so thats why you don’t see it in the toolbar.
Can you double check that you have the trainer paired correctly as power and resistance?
And I just tested running zwift on my Iphone rather than my macbook and it works fine. I suspect an issue on mac even if both devices are running Zwift on v1.124.0 (167761).
Hi I just did a FTP Test in 1.124.0 (also macOS 26.6.2, Van Rysel D500). ERG for me also seems broken. Instead of increasing power every minute by 20W, ERG only got increased every 2min. Also in the cool down afterwards my I couldn’t pedal on my own pace, as ERG was still set to a super high number. Disabling ERG did also not help.
Same issue for us on a Kickr Bike controlled by either an Apple TV or an Android tablet.
Power and resistance pair fine, but ERG workouts do not run in ERG mode. Clicking the ERG mode button during the workout has no effect, nor has power cycling the trainer. All other devices in the vicinity have their Bluetooth switched off.
Thank you for the update @Syl_VAN_DIEUREN Because it’s on and off for us as well I initially thought that it must be some other device still connected to the trainer and monopolizing its resistance control. I’ve had issues like this in the past when some device was still running zwift in the background. But given that you report the same issue at the same time it might also have something to do with the zwift update. Have you tried erg mode with tacx/Garmin’s own app?
Nope I didn’t. Since it worked fine with my Iphone and I only experienced the issue with my mac (both running the exact same Zwift version), I was thinking the issue came from Zwift on mac.
But as it worked just fine yesterday on the same Zwift version I think I’ll just wait to see if the issue happens again.
Since the update where your equipment get remembered we had had issues with the erg mode not activating in workouts. We have two wahoo trainers and depending on who is riding we alternate the trainer that is connected to an Apple TV 4K.
Since the latest update we can connect the the trainers and it shows that the power, resistance and cadence are connected but when you start riding the erg mode doesn’t work. If you check in the menu erg mode is on and toggling it off and on again doesn’t solve the issues. If you switch between companion app connection and back to blue tooth a few times you can get it working but it is very frustrating. Is there an idea for a solution?
