I start a workout. Erg doesnt work during warm up interval, trainer resistance is not controled(erg turned on, no other devices connected). erg only turns on when the timer triggers the next interval, from then on it works fine and changes resistance as expected.
These are workouts ive completed dozens of times.
Android. S20. Zwift and os software up to date
Wahoo core. Software updated.
Shuji at Zwfit HQ here. I’m looking at your server logs from August 21 and seeing several Log In several times from a Samsung SM-G986B before I see a Log out recorded. This can happen for a number of reason, such as when the Zwift app is swiped into the background mid-session, or if you end a session without fully terminating the session. What essentially happens is that concurrent sessions are open at the same time, and this can happen on Android as well as iOS and tvOS.
For the sake of thoroughness - what happens if you reboot your Android device, wait 2 minutes to let our server clear any activity, then log in to Zwift? Does your work out behave in ERG mode as it should?
During the last rest set. 135watts for 5mins. I advanced using on screen button to finish the WO. But resistance was then set to 135 even through i was in resistance/free mode.
