Effects on workout modes
(Mark Hewitt) #1
I don’t mind the effects which are applied which are supposed to simulate you going into tunnel vision -  however I rode the McCarthy Special today which has three intervals, each of which increases wattage compared to the one before, however the effects were applied towards the end of each interval, then at the start of the following interval we went through the arch and emerged into a clear view again - which doesn’t make sense when you’ve just started working *harder*.
So my feature suggestion is that the effects should only be applied towards the end of the interval if the interval to follow is easier.
