Cannot see this having been raised before but for me the Dynamic Climbing Graph centre top of the HUD gets out of Synch with the on-screen road, the top right map gradient and the resistance / tilt of the trainer. This is most noticeable in the hills of France and Titans Grove in Watopia. I wonder if progress up the Dynamic Climbing Graph is based on elapsed distance from the foot of the climb such that if you have steering enabled and are carving corners then your ridden distance is different to where that distance would be on the Dynamic Climbing Graph? That would explain why it is more noticeable on S bend and lumpy sections like Titans Grove where it gets to the point where the Dynamic Climbing Graph shows you on a ramp when you are in dip and vice versa. Anyone else noticed this in these areas / with steering enabled?
@calfzilla points this out all the time with screen shots of where it is not matching. Often in titans grove, and plenty of other areas.
Thanks Mike - I have now found a calfzilla post referring to it as the “offset climb hud bug" Interestingly from the screenshot it was encountered without steering enabled but maybe in a group ride - potentially being pushed out to the side by other riders in a peloton can have the same effect as steering in changing the ride distance from the centreline ride distance Zwift may be using, or maybe the reference points Zwift uses for the dynamic climbing graph are just incorrect …
I noticed today on the grade while spectacting a friend the central climbing graph didn’t change at all the entire time, just frozen in time, however the % did change.
I was alongside them the entire time.
I forget where I noticed this but it was recently, and might have also been titans grove, it was off sync with the gradient graph pretty consistently at one point and once it was off sync it stayed that way for a while.
I’ll keep an eye out and will be clear on where I see it next time.
Were you Zwifting with steering enabled Aaron?
Often notice this in Titans. Also last third or so of Ven-Top. No steering for me.
