Yikes this is.. a big block of text, but fear not, it’s mostly just numbers you can skip over until the bottom.
I think I summed it up pretty clearly on the last dropshop update page that the prices are absurd.
The fact that the better of the two new Van Rysel road bikes is more expensive, and despite having the same star ratings as bikes that were in the 700,000
range but cost 1,500,000
is plenty of enough explanation.
All of the new bikes take quite literally 2x or more time to unlock for the same
ratings.
The schema has been thrown out the window.
Let’s dig a little deeper though and actually look at some really basic math.
I’ll use the same comparison I did on the VR bikes on that thread since I’m familiar.
The new Van Rysel RCR-F dropped on 1.113 with a double
rating.
The older Giant Propel and TCR match the RCR-F also with a double 3 star rating.
(Previously I only compared the TCR, Propel will make sense in a second).
Based on the useless
rating, but seeing how these 3 bikes match, let’s compare prices.
Giant TCR SL 2021: 566,100
Giant Propel SL Disc (circa 2018): 1,102,900
Van Rysel RCR-F: 1,500,000
Pinarello Dogma F 2021: 1,350,000
but wait, this is a
bike! (4 and 3 technically)
Seems quite lopsided already.
Really rough stats comparison, the old TCR is kind of rubbish. The old Giant Propel is not terribly far behind on aero, but considerably more heavy.
The old Dogma 2021 however… is extremely similar in stats (we’re talking… Insider test, 2 seconds difference climbing, 4 seconds flat.. over the hour. Where the Propel is same flat, but 16s slower on climb)
Total upgrade path cost + frame:
Giant TCR SL 2021: 1,316,100
Giant Propel SL Disc (circa 2018): 3,002,900
Pinarello Dogma F 2021: 3,250,000
Van Rysel RCR-F: 3,400,000
Note that gap with the old TCR. Actually I haven’t done this math so the Propel takes my by surprise that it’s a high-end. Let’s put that into time though; drop numbers are IMO pretty meaningless until we look at the actual time gaps.
I agree with Peter, the 30k range an hour is close enough to what I experience as well.
Giant TCR SL 2021: 19 hours
Giant Propel SL Disc (circa 2018): 37 hours
Pinarello Dogma F 2021: 45 hours
Van Rysel RCR-F: 50 hours
upgrades:
Giant TCR SL 2021: 43 hours
Giant Propel SL Disc (circa 2018): 100 hours
Pinarello Dogma F 2021: 108 hours
Van Rysel RCR-F: 113 hours
Zwift Entry full upgrade 0-5: 13 hours
Thought that last one would be fun to add.
Purchase + Upgrade:
Giant TCR SL 2021: 62 hours
Giant Propel SL Disc (circa 2018): 137 hours
Pinarello Dogma F 2021: 153 hours
Van Rysel RCR-F: 163 hours
Concept: 667 hours
I think just knowing that it takes 33 hours to produce 1 million drops is all one really needs to know… and how many weeks that takes the average user.
What did we learn?
Probably more of what we knew; the star system is a junk rating system and either needs reviewing or replacing to 5 stars. We also learned a former generation bike and a Zwift bike can be fully upgraded in the time it takes to upgrade a newer frame due to the increase in cost.
10 more hours though even for a bike that’s been around as a previous generation and nearly matches the abilities is still significant; for most people that’s easily another full week of riding, or a lot more depending on the user.
What’s really worth noting again is that the TCR listed is the same 3 star rating, and it’s 100 hours less. I guess if anything, it just proves again that the star rating needs an overhaul; and if it doesn’t go to 5 stars, perhaps a logarithmic system or curved would be far more useful…
These are still massively high numbers; the concepts for sure are for the dedicated, that much can be stated.
