Hi all
I have just purchased a Zwift Cog and want to fit it to my Tacx Neo 2T.
I currently have a campagnolo cassette body on there and I cannot remove it (rounded 5mm allen key hole!)
So does anyone know if the zwift cog fit on both Shimano and Campagnolo cassette bodies? Or do I need to take the cassette body off and refit the Shimano one?
John
The Cog is designed to fit Shimano 11 speed Hyperglide freehubs, not Campagnolo.
You could just continue to run your Campagnolo cassette instead of the Zwift Cog, which is just a single speed cog surrounded by plastic. All the virtual shifting happens between the Click / Play controllers, Zwift & your trainer, the cog isn’t doing anything.
If you really want only one cog on your trainer, you could just get a single speed kit for the Campagnolo cassette body.
Or you could just finally deal with that rounded bolt if you want to use the Cog.
Thanks both
Ill see if i can get the end cap off. Garmin said theyd send a replacement if i damaged it
Made of cheese I think
Great idea on the single cassette
Using a brand new hex wrench sometimes helps since the edges are sharper.
If I had that problem I would use an “EZ Out” type of bolt extractor like this sort of thing:
