Hi guys,
I installed Direto X and there is a problem. Wher I go at aprox 70 RPM, RPM in Zwift jumps from 0 to 70, the same for Watts, from 0 to hundreds…speed 0 to 30. Anybody can help?
I did the setup in MyTraining, I wake up the trainer and THAN i start Zwift… I have BT and Ant+, regular PC…
So, is there any guide? There are several trainers available in Zwift menu - I tried them all, but none of them worked:( Is tehre any trick how to make Direto X working with Zwift?
Thank you, Jan
